[GRASS-dev] WxPython prototype GRASS GUI. Version 2
Yann Chemin ychemin at gmail.com
Mon Aug 7 23:54:10 EDT 2006
Hi Michael,
Here is an updated gism.py with the vector module completed,
enjoy!
Yann
On 08/08/06, Yann Chemin <ychemin at gmail.com> wrote:
> Hi Michael,
> please incorporate the r.mapcalc fix from Glynn.
> Yann
> ---------- Forwarded message ----------
> From: Yann Chemin <ychemin at gmail.com>
> Date: 08-Aug-2006 09:21
> Subject: Re: [GRASS-dev] WxPython prototype GRASS GUI. Version 2
> To: Glynn Clements <glynn at gclements.plus.com>
> Cc: Grass Developers List <grass-dev at grass.itc.it>
> Thanks Glynn !
> It works well.
> here are the modifications:
> in gism.py replace:
> ("Map calculator", "Map calculator", self.runMenuCmd, "r.mapcalc"),
> with this:
> ("Map calculator", "Map calculator", self.runMenuCmd, "mapcalc_gparser.sh"),
> and add the Glynn file attached (mapcalc_gparser.sh) to the py_gm directory.
> it opens a r.mapcalc dialog box where one can enter equations.
> Yann
> > nice!
> > ok, i'll try.
> > thanks,
> > Yann
> > On 08/08/06, Glynn Clements <glynn at gclements.plus.com> wrote:
> > > Yann Chemin wrote:
> > > > Sorry to ask this new bie question, but you mean that the front-end
> > > > should be a file called from the GUI and this front-end will somehow
> > > > launch r.mapcalc, don't you?
> > > Yes. The front-end would be a g.parser script with one option,
> > > expression=, and it would invoke r.mapcalc on that expression.
> > > Unlike r.mapcalc, a script which uses g.parser will accept all
> > > G_parser() options, e.g. --interface-description.
Type: text/x-python
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20060808/ff6cca81/gism.py
