[GRASS-dev] creating new modules
    Hamish
    hamish_nospam at yahoo.com
    Thu Aug 24 18:06:21 EDT 2006
Kirk Wythers wrote:
> The goal here is to write a module r.pnet. PnET is a general
> ecosystem model that does carbon, water and nitrogen balance. It can
> output things like gross and net primary production, net ecosystem
> production, plant and ecosystem respiration, etc.
> In it's present form PnET requires a file of vegetation parameters,
> and a file of climate parameters (climate inputs are temporal, i.e.
> daily time step would have one day of temps, precipitation, and solar
> radiation per line). However, on a spatial application such as this,
> climate will vary both temporally and spatially, therefore I will
> need a multidimensional data holder for climate inputs.
> Presently the vegetation parameters are in individual files based on
> cover type (for example, one file for oak, one file for maple, one
> file for pine, one file for corn, etc...
> I am envisioning a GRASS module that takes a input raster of land
> cover, and for each pixel, gets the vegetation parameters associated
> with the land cover type, gets climate data for the current time step
> (that day for example), then runs the PnET model for that pixel, then
> writes it's output, before moving on to the next pixel.
> Perhaps a good start would be to write some over simplified PnET code
> into the "does nothing" portion of r.example and see if I can get
> anything working?
How complicated is the PnET model? e.g. can you write a prototype using
r.mapcalc or a series of r.mapcalc commands? If the model is relatively
simple, that would be my first step.
Hamish
