[GRASS-dev] creating new modules
hmitaso at ncsu.edu hmitaso at ncsu.edu
Sat Aug 26 16:10:31 EDT 2006
Kirk, I am not sure whether Massimiliano Cannata reads this list but he has
developed a set of modules, in fact entire environment that does quite a few
of tasks that you are discussing here. You may want to check the abstract for
HydroFOSS at foss4g2006.org (if it is not yet available it should be in
few days)
and see whether there are some lessons to be learned from his work or
whether you can coordinate the development.
Helena
> Kirk Wythers wrote:
>> The goal here is to write a module r.pnet. PnET is a general
>> ecosystem model that does carbon, water and nitrogen balance. It can
>> output things like gross and net primary production, net ecosystem
>> production, plant and ecosystem respiration, etc.
>> In it's present form PnET requires a file of vegetation parameters,
>> and a file of climate parameters (climate inputs are temporal, i.e.
>> daily time step would have one day of temps, precipitation, and solar
>> radiation per line). However, on a spatial application such as this,
>> climate will vary both temporally and spatially, therefore I will
>> need a multidimensional data holder for climate inputs.
>> Presently the vegetation parameters are in individual files based on
>> cover type (for example, one file for oak, one file for maple, one
>> file for pine, one file for corn, etc...
>> I am envisioning a GRASS module that takes a input raster of land
>> cover, and for each pixel, gets the vegetation parameters associated
>> with the land cover type, gets climate data for the current time step
>> (that day for example), then runs the PnET model for that pixel, then
>> writes it's output, before moving on to the next pixel.
>> Perhaps a good start would be to write some over simplified PnET code
>> into the "does nothing" portion of r.example and see if I can get
>> anything working?
> How complicated is the PnET model? e.g. can you write a prototype using
> r.mapcalc or a series of r.mapcalc commands? If the model is relatively
> simple, that would be my first step.
> Hamish
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
