[GRASS-dev] Re: winGRASS
Moritz Lennert mlennert at club.worldonline.be
Mon Dec 11 10:18:05 EST 2006
Hello Paul,
(cc'ing this to the list, so that Paul is not alone...)
On 09/12/06 15:56, Paul Kelly wrote:
> Hello Moritz
> On Fri, 8 Dec 2006, Moritz Lennert wrote:
>> Hello Paul,
>> I'm finally sitting in front of a Windows computer trying to compile
>> GRASS
>> myself.
>> On Thu, November 23, 2006 12:38, Paul Kelly wrote:
>>> I had a look at that site; certainly lots of useful information on
>>> building there. E.g. I don't expect they will have the stripped-down XDR
>>> or GDAL or PROJ, and they were the biggest challenges to build properly
>>> anyway.
>> At this stage I just used ./configure;make;make install, just to see
>> whether everything seems to work.
>> I imagine I will need to do some more tweaking, would happen to have
>> recorded your configure settings somewhere ?
> For the other software, no net yet. Some of it I think I just used the
> Makefiles as the configure script wasn't working on Windows. But I
> intend to re-build it all from scratch very soon and will take proper
> notes then.
I've tried to build GRASS having just compiled the other libraries with
configure&make&make install.
I get the following error:
c:/Moritz/gdal-cvs-2006.12.07/libgdal.la: file not recognized: File
format not recognized
collect2: ld returned 1 exit status
make[2]: ***
[/c/moritz/grass6/dist.i686-pc-mingw32/lib/libgrass_gproj.6.3.cvs.dll]
Error 1
and
make[3]: ***
[/c/moritz/grass6/dist.i686-pc-mingw32/lib/libgrass_vect.6.3.cvs.dll]
Error 1
which then obviously leads to many errors afterwards.
I have attached the entire make log and the libgdal.la file.
Any ideas of what is wrong with the .la file ?
Also, I've seen some debate on cross-compiling lately. If this is
reasonably easy, it would make life easier for me as I would not have to
wait for my colleague's windows machine to be free...
Moritz
# libgdal.la - a libtool library file
# Generated by ltmain.sh - GNU libtool 1.5.2 (1.1220.2.60 2004/01/25 12:25:08) Debian: 192 $
# Please DO NOT delete this file!
# It is necessary for linking the library.
# The name that we can dlopen(3).
dlname='../bin/libgdal-1.dll'
# Names of this library.
library_names='libgdal.dll.a'
# The name of the static archive.
old_library='libgdal.a'
# Libraries that this one depends upon.
dependency_libs=' -lpng -lz'
# Version information for libgdal.
current=12
age=11
revision=0
# Is this an already installed library?
installed=yes
# Should we warn about portability when linking against -modules?
shouldnotlink=no
# Files to dlopen/dlpreopen
dlopen=''
dlpreopen=''
# Directory that this library needs to be installed in:
libdir='/usr/local/lib'
Type: application/x-gzip
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20061211/40d5425b/make.log.gz
