[GRASS-dev] NVIZ startup
Michael Barton michael.barton at asu.edu
Mon Dec 11 14:48:49 EST 2006
Given Paul Kelly's reply, we might want to revert this until the Windows
issues are sorted out. Thanks for trying to help with debugging though.
Michael
On 12/11/06 7:12 AM, "Bob Covill" <bcovill at tekmap.ns.ca> wrote:
> Hello,
> I have updated NVIZ so that it is now started via a script (still called
> nviz). This update should improve the TCL error catching of NVIZ. TCL
> errors should now be printed to stderr. The previous version would hang
> or dump the user out without any indication of the TCL error causing the
> problem.
> The un-installed script can be found in nviz/scripts. Please check it
> out and see if any improvements can be made.
> This update also includes modifications to the nviz Makefile. The script
> is currently being installed in $GISBASE/bin, but it should probably be
> installed in $GISBASE/scripts. Unfortunately I do not know how to remove
> the old nviz in $GISBASE/bin before installing the script in
> $GISBASE/scripts. There is also a couple lines in Makefile to handle
> moving the binary nvwish to $GISBASE/etc/nviz2.2/. Please check this
> section to ensure that is is correct (particularly Windows developers).
> Bob
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
