[GRASS5] New release candidate 3 of GIS Manager 2
Wed Feb 15 22:28:17 EST 2006
Michael Barton wrote:
> > Right! Thanks! I was only clicking the "Map Display" window title bar,
> > thought this should be enough. And - could it be enough? Would improve
> > things I believe.
> The top title bar is the only place on the window I can't get the mouse
> click to register. I don't know why.
The title bar belongs to the window manager; mouse clicks there will
not be reported to the application.
If the WM implements a click-to-focus policy, you may receive a
FocusIn event when the window is selected. Also, you might receive a
Configure event if the WM changes the window's position in the
stacking order.
> >>> The "run", "clear", "save", "open output window" buttons in the
> >>> bottom of main gis.m window get hidden when I drag the layer display
> >>> options window to the bottom. Could they be permanent, not possible
> >>> to hide? (We don't want to hide them, what for?)
> >> I don't understand what you are doing here.
> > See the attached screendump: don't let the buttons (1) get hidden when
> > the slider (2) is drragged to the bottom.
> Thanks for the graphic explaining this. I don't know how to avoid this. If
> you expand the total height of the GIS Manager control window, it helps to
> some extent, but does not get rid of this issue. Maybe someone else has an
> idea???
Re-arrange the widget hierarchy so that the buttons aren't descendents
of the paned window.
