[GRASS5] [bug #4118] (grass) can not use d.erase -f
Mon Feb 27 11:59:32 EST 2006
Markus Neteler wrote:
> > > this bug's URL: http://intevation.de/rt/webrt?serial_num=4118
> > > Subject: can not use d.erase -f
> > > Platform: WindowsNT/2000/XP
> > > grass binary for platform: Downloaded precompiled Binaries
> > > GRASS Version: GRASS 6.0.0 (2005)
> > > I can not use "d.erase -f" to remove the frames when clearing the
> > > display, after using "d.rast.leg" as what's said on the Reference
> > > Manual.
> > > Here is screen info:
> > > GRASS 6.0.0 (spearfish):~ > d.erase -f
> > > Sorry, <f> is not a valid flag
> > The -f flag isn't present in 6.0.0. It was added on 2005/06/21, so you
> > will need a version which was released after that date.
> > [BTW, neither 6.0.1 nor 6.0.2 appear to have CVS tags, so it's
> > impossible to determine which version of a file was used for those
> > releases.]
> Good point. I'll tag 6.0.2 now and update the release procedure.
If you've done "cvs update" since the release, "cvs tag" will apply
the tag to the updated versions, not the versions in the release. In
that case, you can use "cvs rtag -D <date> ..." with the correct date
(the time of the "cvs update" command corresponding to the released
versions) instead.
BTW, I would suggest leaving the CVS directories in the tarballs, so
that someone can use "cvs update" to get a later version. Ideally, the
CVS/Root files should be set for anonymous (pserver) access, but it's
easy enough to replace them using a script if you have a copy which
was checked out using ssh.
