[GRASS-dev] v.edit
Jachym Cepicky jachym.cepicky at centrum.cz
Tue Jun 6 05:43:05 EDT 2006
Hallo,
great work
On Tue, Jun 06, 2006 at 10:30:47AM +0300, Wolf Bergenheim wrote:
> Ok now v.edit's add functionality is completed. One can add
> point,line,area,boundary,centroid. Boundaries will not be given a cat.
> Adding an area tries to put a centroid in the geographic mean, and if it
> fails it will exit, with nothing added.
> if you give many co-ordinates when adding a point many points will be
> generated.
> The cat support includes support for many cat's and ranges. This is for
> instance supported:
> 	v.edit map=test cat=267,347-350,353,356-359 coords=...
> And if there are more points then given cats, the cat will just be
> increased by one. The example above will result in 10 cats:
> 267,347,348,349,350,353,356,357,358 and 359. If you give 11 point the
> eleventh point will get the next cat (which is 360)
> --Wolf
Why should a boundary NOT have category too? How would you distinguish
two different types of boundary arround one area? Example on
http://les-ejk.cz/tmp/boundaries.gif
One country (Sachsen) has 2 different types of boundaries (country and
state).
I thing, it is usefull to have a possibility for adding category number
(and attributes) to boundary too.
Or do I understand it wrong?
Jachym
Jachym Cepicky
e-mail: jachym.cepicky at centrum.cz
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/gnupg_public_key/jachym_cepicky-gpg_public_key.asc
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
e-mail: cepicky at gdf-hannover.de
URL:    http://gdf-hannover.de
Tel.:   +49 511-39088507
Name: not available
Desc: Digital signature
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20060606/ca659d97/attachment.bin
