[GRASS-dev] Projection-problem
Paul Kelly paul-grass at stjohnspoint.co.uk
Thu May 11 10:55:12 EDT 2006
On Thu, 11 May 2006, Stephan Holl wrote:
>> I would be grateful if you could let me know if this works. However,
>> as far as I can see, the spatial subregion code still seems to assume
>> that only one layer is being imported---can anybody confirm this?
> Cool, Paul. This works for me now!
> Perhaps anybody can confirm this as well and commit it to CVS?
OK well I can't see any problems with it so I have committed. Perhaps it
would be an idea to exit with an error if the spatial= functionality is
being used when more than one layer is being imported, but certainly it
should also be working better too now I think as it would have also been
potentially using the wrong layer before.
Paul
