[GRASS-dev] ./configure error
Markus Neteler neteler at itc.it
Mon May 15 12:38:09 EDT 2006
On Mon, May 15, 2006 at 06:30:31PM +0200, Paolo Cavallini wrote:
> Following:
> http://www.intevation.de/rt/webrt?serial_num=3918&display=History
> I ran:
> /usr/src/grass# autoconf
> configure.in:366: warning: AC_CANONICAL_HOST invoked multiple times
> autoconf/specific.m4:362: AC_CYGWIN is expanded from...
> configure.in:366: the top level
NO good!
You have to use the old autoconf (autoconf-2.13) IF you want to use it.
But better don't use it and use the file from CVS instead.
> ./configure now stops at:
> checking if 64bit Sparc VIS support is requested... no
> checking system version (for dynamic loading)... ./configure: line 8097:
> syntax error near unexpected token `('
> ./configure: line 8097: `    case `(uname -sr) 2>/dev/null` in'
> running it with -x stops at:
> + echo 'LTLIBOBJS='\'''\'''
> + echo
> + test -n ''
> + test -s confdefs.h
> + cat
> + echo
> + sed '/^$/d' confdefs.h
> + sort
> + echo
> + test 0 '!=' 0
> + echo 'configure: exit 258'
> + rm -f core '*.core'
> + rm -rf 'conftest*' confdefs.h 'conf22817*'
> + exit 258
> Dos this help understanding the problem?
Not really - I don't see the error message which you posted
earlier. The idea was to not run autoconf* but to run -x
on the original file in CVS (which I just used again, it is
ok).
ciao
 Markus
> At 16:11, lunedì 15 maggio 2006, Markus Neteler has probably written:
> > >While installing on a high-end machine [1], at ./configure I get:
> > >checking system version (for dynamic loading)... ./configure: line 12467:
> > >syntax error: unexpected end of file
> > >The file seems ok. Any suggestion?
> > You could change the first row of 'configure'
> > from
> > #! /bin/sh
> > to
> > #! /bin/sh -x
> > then launch again and see more details.
> > Markus
> > grass-dev mailing list
> > grass-dev at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass-dev
> Paolo Cavallini
> email+jabber: cavallini at faunalia.it
> www.faunalia.it
> Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy   Tel: (+39)348-3801953
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
