[GRASS-dev] ./configure error
Paolo Cavallini cavallini at faunalia.it
Mon May 15 13:00:03 EDT 2006
OK, so I ran ./configure (with -x, without autoconf) again and I got:
+ echo ranlib
ranlib
+ echo -n 'checking how to run the C preprocessor... '
checking how to run the C preprocessor... + echo 'configure:1758: checking how
to run the C preprocessor'
+ test -n ''
+ test -z ''
+ CPP='gcc -E'
+ cat
+ ac_try='$CPP $CPPFLAGS conftest.c >/dev/null 2>conftest.out'
+ eval echo configure:1777: '"$CPP' '$CPPFLAGS'
conftest.c '>/dev/null' '2>conftest.out"'
++ echo configure:1777: 'gcc -E  conftest.c >/dev/null 2>conftest.out'
++ grep -v '^ *+' conftest.out
++ grep -v '^conftest.c$'
+ ac_err=
+ test -z ''
+ rm -f conftest.c conftest.out
+ ac_cv_prog_CPP='gcc -E'
+ CPP='gcc -E'
+ echo 'gcc -E'
gcc -E
+ echo -n 'checking if 64bit support is requested... '
checking if 64bit support is requested... + echo 'configure:1839: checking if
64bit support is requested'
+ test '' = set
+ enableval=no
+ test no = yes
+ do64bit=no
+ echo no
no
+ echo -n 'checking if 64bit Sparc VIS support is requested... '
checking if 64bit Sparc VIS support is requested... + echo 'configure:1859:
checking if 64bit Sparc VIS support is requested'
+ test '' = set
+ enableval=no
+ test no = yes
+ do64bitVIS=no
+ echo no
no
+ echo -n 'checking system version (for dynamic loading)... '
checking system version (for dynamic loading)... + echo 'configure:1883:
checking system version (for dynamic loading)'
./configure: line 12467: syntax error: unexpected end of file
At 18:38, lunedì 15 maggio 2006, Markus Neteler has probably written:
> > Dos this help understanding the problem?
> Not really - I don't see the error message which you posted
> earlier. The idea was to not run autoconf* but to run -x
> on the original file in CVS (which I just used again, it is
> ok).
> ciao
>  Markus
Paolo Cavallini
email+jabber: cavallini at faunalia.it
www.faunalia.it
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy   Tel: (+39)348-3801953
