[GRASS-dev] [bug #4480] (grass) v.to.rast: contradictory errors reported when column doesn't exist in input
Request Tracker grass-bugs at intevation.de
Sun May 21 14:03:43 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=4480
Subject: v.to.rast: contradictory errors reported when column doesn't exist in input
Platform: GNU/Linux/x86
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: 2006-05-17
v.to.rast column=non_existant_column:
A proper DBMI error is printed:
   Loading vector information ...DBMI-DBF driver error:
   Column 'value' not found
   Error in db_open_select_cursor()
But the modules last words misslead the user reporting a different error:
   GRASS_INFO_ERROR(27611,1): Column type not supported
Maciek
-------------------------------------------- Managed by Request Tracker
