[GRASS-dev] v.edit initial version
Wolf Bergenheim wolf+grass at bergenheim.net
Fri May 26 06:47:09 EDT 2006
Hi!
I added v.edit to the CVS. This initial version can only add points (one
or many) to a map. It does not touch the database yet.
I have a problem with the field variable in Vect_cat_set and friends. What
does it mean and what does it do? In my tests it seem that it should be
1... Can someone explain it? Also what does it have to do with the fields
member of the line_cats structure?
--Wolf
<:3 )---- Wolf Bergenheim ----( 8:>
