[GRASS-dev] v.edit initial version
Michael Barton michael.barton at asu.edu
Fri May 26 13:28:09 EDT 2006
Wow. That was fast.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Wolf Bergenheim <wolf+grass at bergenheim.net>
> Date: Fri, 26 May 2006 13:47:09 +0300 (EEST)
> To: GRASS developers list <grass-dev at grass.itc.it>
> Subject: [GRASS-dev] v.edit initial version
> Hi!
> I added v.edit to the CVS. This initial version can only add points (one
> or many) to a map. It does not touch the database yet.
> I have a problem with the field variable in Vect_cat_set and friends. What
> does it mean and what does it do? In my tests it seem that it should be
> 1... Can someone explain it? Also what does it have to do with the fields
> member of the line_cats structure?
> --Wolf
> <:3 )---- Wolf Bergenheim ----( 8:>
