[GRASS-dev] [bug #5264] (grass) v.digit - G_malloc out of memory error
Markus Neteler neteler at itc.it
Sat Nov 11 10:29:54 EST 2006
On Fri, Nov 10, 2006 at 06:50:12PM +0100, Maciek Sieczka via RT wrote:
> > When trying to edit an existing vector file, the following message appears:
> > v.digit  map=filename
> > ERROR: Cannot open old vector filename4 at PERMANENT on level 2
> That's because v.digit crashes and leaves the vector without topology.
v.digit should be(come) friendly and run v.build (or the equivalent C stuff)
to reconstruct the topology.
Markus
