[GRASS-dev] [bug #5264] (grass) v.digit - G_malloc out of memory
	error
    Maciek Sieczka via RT
    grass-bugs at intevation.de
    Fri Nov 10 12:50:12 EST 2006
guest wrote (Fri, Nov 10 2006 02:31:16):
> trying to create a new vector file results in the following error:
> v.digit -n map=testv2
> New empty map created.
> ERROR: G_malloc: out of memory
Hi, thanks for the report. v.digit works for me. Nobody seems to be confirming
this bug. So a few questions:
GRASS version exactly?
Linux?
region settings?
tcl/tk version (build time and run time, if different)?
> When trying to edit an existing vector file, the following message appears:
> v.digit  map=filename
> ERROR: Cannot open old vector filename4 at PERMANENT on level 2
That's because v.digit crashes and leaves the vector without topology.
Thanks,
Maciek
-------------------------------------------- Managed by Request Tracker
