[GRASS-dev] [bug #5158] (grass) v.to.db option=query: SQL parser error in statement if no qcolumn specified
Request Tracker grass-bugs at intevation.de
Thu Sep 21 08:21:46 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=5158
Subject: v.to.db option=query: SQL parser error in statement if no qcolumn specified
Platform: GNU/Linux/x86
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: 2006-09-21
Hi
In spearfish60/PERMANENT:
$ v.to.db -p map=landuse option=query column=label
Reading data trom the map ...  100%
Querying database ... DBMI-DBF driver error:
SQL parser error in statement:
SELECT (null) FROM landuse WHERE cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1 OR cat = 1
Error in db_open_select_cursor()
ERROR: Cannot open cursor: 'SELECT (null) FROM landuse WHERE cat = 1 OR cat
       cat = 1'
An error like "You must specify 'qcolumn' for 'option=query'" should be issued instead.
Maciek
-------------------------------------------- Managed by Request Tracker
