[GRASS-dev] r.random still broken on Mac
Fri Sep 29 13:46:22 EDT 2006
William Kyngesburye wrote:
> I just did a quick test - removed __APPLE__ from r.random, so it uses
> the extern lrand48.  I now get a random distribution.
So it's the fake lrand48() that's causing problems?
Doh.
#define lrand48() ((long)((double) rand() * (1<<31) / RAND_MAX))
This produces the correct range, but if RAND_MAX is too small, the
bottom bits will all be zero. The result is actually used as:
            if (make_rand() % nc < nt)
so it's the bottom bits which are the most relevant.
Can you try this instead:
#define lrand48() (((long) rand() ^ ((long) rand() << 16)) & 0x7FFFFFFF)
