[GRASS-dev] r3.stats and heapsort
Sören Gebbert soerengebbert at gmx.de
Mon Feb 19 06:12:42 EST 2007
Dear devs,
i have implemented a new raster3d module called r3.stats.
This module calculates volume statistics for raster3d maps.
The functionality is mostly similar to r.stats, except the category
support for raster3d maps (AFAIK categories are implemented in g3dlib
but not used) and the output format (i dont see the necessity of dozen
format flags).
r3.stats calculates volume statistics based on subranges like r.stats
and volume statistics based on groups of unique values. Examples are
available in the documentation of the module.
http://www-pool.math.tu-berlin.de/~soeren/grass/modules/r3.stats.tar.bz2
This module is implemented from scratch, its not based on the code of
r.stats. Because r.stats has a bug in computing subrange statistics
which i was not able to correct. :(
r3.stats is not that sophisticated like r.stats, because it does not use
  linked lists and hash tables, it can be very memory consuming and i
guess it is by far not as fast as r.stats. Because of the quadratic
complexity for subrange calculations, the number of subranges is limited
  to 1 - 100000.
r3.stats uses heapsort to calculate groups of equal values. Because of
this and the fact that r3.univar uses heapsort and r.univar hopefully
soon too, i would like to add heapsort as library function to grass:
extern int G_heapsort_int(int *array, int num);
extern int G_heapsort_float(float *array, int num);
extern int G_heapsort_double(double *array, int num);
Important:
Please do not test r3.stats bevor i have submitted the data type patch i
have announced one day befor.
Best regards
Soeren
