[GRASS-dev] CVS error?
Thu Jan 25 04:23:49 EST 2007
Hamish wrote:
> trying to do a CVS diff on an anonymous CVS snapshot checkout:
> grass63$ cvs -q diff
> cvs server: failed to create lock directory for `/home/grass/grassrepository/grass6/gem/skeleton/macosx' (/home/grass/grassrepository/grass6/gem/skeleton/macosx/#cvs.lock): No such file or directory
> cvs server: failed to obtain dir lock in repository `/home/grass/grassrepository/grass6/gem/skeleton/macosx'
> cvs [server aborted]: read lock failed - giving up
> any ideas?
	rm -rf gem/skeleton/macosx
So far as the CVS server is concerned, that directory never existed.
You need to manually bring your working copy into line with the
server's view of reality.
[See the "What is a binary executable doing in CVS?" thread for the
backstory.]
