[GRASS-dev] d.rast.edit replacement candidate
Tue Mar 13 09:32:07 EDT 2007
Glynn Clements wrote:
> If editing large maps is desirable, another option is to use a scaled
> image rather than drawing each cell as a polygon.
Actually, that doesn't help much; I forgot that the Tk canvas doesn't
allow images to be scaled, and scaling the image itself increases
memory consumption proportionally, making it potentially worse than
using a polygon per cell.
