[GRASS-dev] problems with mkftcap
William Kyngesburye woklist at kyngchaos.com
Wed May 2 15:36:07 EDT 2007
Sorry, responding to myself again...
On May 2, 2007, at 2:11 PM, William Kyngesburye wrote:
> On May 2, 2007, at 10:41 AM, William Kyngesburye wrote:
>> I'm having a different problem with mkftcap - it's getting hung up
>> doing nothing.  One on my processors maxes out and there is no
>> disk activity for the find operations.
>> I tried cutting out each part separately - find and fc-list - to
>> see if one of those was the problem, but no go.
>> Further cutting points to something wrong in the sed lines - if I
>> remove those so the raw find and fc-list results are returned, it
>> finishes.
> I found the source of my problem - in my .bash_profile, I set:
> export LC_CTYPE="en_US.UTF-8"
> export LANG="en_US.UTF-8"
> if I unset both, mkftcap works.  I also have:
> set dspmbyte = \"utf8\"
> but I don't need to change that for mkftcap to work.
> I set these (maybe naively?) so my Terminals match the default OSX
> charset of utf8.  The window display settings for Terminal.app
> default to utf8 (and I didn't need to change that either).
After trying various combinations of these settings, it appears I
don't need these any more.  They are probably leftovers in
my .bash_profile from the early OSX days when Terminal didn't handle
UTF8 directly very well.  It looks like the window setting takes care
of this now.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
All generalizations are dangerous, even this one.
