[GRASS-dev] problems with mkftcap
William Kyngesburye woklist at kyngchaos.com
Wed May 2 20:44:20 EDT 2007
more trouble...
Now that mkftcap is not hanging for me, next problem.  For some
reason the resource fonts are getting filtered out.
The first part, listing ttf, seems to be working.  The fc-list part
should work - alone, the fc-list :outline file index command shows
all the fonts.  But after the sed, they're gone.  Could it be because
they don't have a file extension?
Here's a small clip of the raw fc-list output:
/System/Library/Fonts/Times.dfont: :index=0
/Library/Fonts/Arial Narrow: :index=0
/System/Library/Fonts/ヒラギノ角ゴ Std W8.otf: :index=0
/System/Library/Fonts/Apple LiGothic Medium.dfont: :index=0
/Library/Fonts/Arial Rounded Bold: :index=0
/Library/Fonts/Times New Roman: :index=0
/Library/Fonts/Andale Mono: :index=0
/System/Library/Fonts/ZapfDingbats.dfont: :index=0
/System/Library/Fonts/Hei.dfont: :index=0
Arial Narrow, Arial Rounded Bold, Times New Roman and Andale Mono
disappear after the sed.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an
illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
