[GRASS-dev] Re: how to check for system in TclTk
Paul Kelly paul-grass at stjohnspoint.co.uk
Mon May 7 08:13:27 EDT 2007
On Sun, 6 May 2007, Michael Barton wrote:
> I've fixed this in the CVS, so that setting the default font should work
> with Windows now.
OK thanks I made a few more changes and now it is working quite well. Most
notably that the
global env, tcl_platform
syntax didn't work (env(GISBASE) was an unknown variable) and I had to
change it to:
global env
global tcl_platform
(which is what the Tcl documentation suggests anyway; ISTR coming across
this before but it seemed to be OK then. Not too sure.)
The other noteworthy change was using the Native Tk file browser widget
::tk::dialog::file:: instead of the native Windows one that tk_getOpenFile
uses. The native Windows one was very slow and clunky and most
importantly didn't work for selecting fonts from the Windows fonts
directory. Clicking on a file didn't put it into the selection box and
double-clicking opened a Window displaying the font's capabilities. The
native Tk widget admittedly has a distinct early-90s look to it but it is
fast and (most importantly) works.
Paul
