[GRASS-dev] Re: how to check for system in TclTk
Mon May 7 10:18:01 EDT 2007
Paul Kelly wrote:
> > I've fixed this in the CVS, so that setting the default font should work
> > with Windows now.
> OK thanks I made a few more changes and now it is working quite well. Most
> notably that the
> global env, tcl_platform
> syntax didn't work (env(GISBASE) was an unknown variable) and I had to
> change it to:
> global env
> global tcl_platform
You can specify multiple variables in a single "global" statement, but
there shouldn't be any commas. "global env, tcl_platform" will attempt
to import a variable named "env," (with a trailing comma).
