[GRASS-dev] d.histogram scale bug [was: not quite there on fonts]
Tue May 15 03:40:07 EDT 2007
> > Hamish:
> >>> ok, so bug #1977 still matters. (axes tags somewhat broken for FP
> >>> maps)
> >>>   http://intevation.de/rt/webrt?serial_num=1977
> > it only happens for some FP maps, for some window sizes.
> > try: (spearfish)
> >  d.mon x0
> >  d.histogram slope
> > then adjust the window size by grabbing the side of the frame.
> > rinse & repeat.
> > If I try that elevation.10m with a narrower window width the x units
> > disappear altogether.
Michael:
> But it is interesting that I can try all kinds of window geometry with
> the display in wxgrass and the worst I get is that 1) the x-axis
> numbers don't display (very skinny histogram) or 2) the font size of
> the y-axis numbers and 1st x-axis number is larger than the size of
> the rest of the x-axis numbers.
> This is with output from the PNG driver.
In new Tcl GIS.m, add histogram button, mapname->slope at PARMANENT, redraw.
... Shows the overlapping numbers.
Hamish
