[GRASS-dev] WinGrass testing results 6.3.0rc2
Michael Barton michael.barton at asu.edu
Mon Nov 26 15:17:20 EST 2007
Moritz and Benjamin,
I¹ve had a couple of students install the new winGRASS 6.3.0RC2 binary and
test it. The main remaining problems are (hopefully) easy to fix. See below.
The PROJ_SHARE variable is not set correctly
NVIZ won¹t launch (but did in a recent binary)
Other stuff seems to be working fine. Hopefully you¹ll be able to fix NVIZ
soon. The PROJ_SHARE issue should be easy.
Benjamin, any hope for the all-in-one *.exe package soon?
Michael
Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> ------ Forwarded Message
> From: Sean Bergin <sbergin at asu.edu>
> Reply-To: <Sean.Bergin at asu.edu>
> Date: Mon, 26 Nov 2007 13:06:57 -0700
> To: Michael Barton <Michael.Barton at asu.edu>
> Subject: WinGrass Problems
> Michael,
> Here are some of the problems Alex and I noticed:
> The EPSG Code Browser tries to find the code at :
> /c/grass63RC2/share/proj/epsg  , and it should be
> C:/grass63RC2/share/proj/epsg  once entered, everything seems to work ok,
> although only once, if you restart it continues to look in the wrong place...
> NVIZ:  if NVIZ is run from the menu, you get child killed: Sigabrt / then a
> box that says dialog 0 opens.  If it is run from the map window, it crashes
> with chil process exited abnormally.
> Sean
> Sean Bergin
> Ph.D. Student, Archaeology
> Graduate Assistant, Integrating Socio-Ecological Sciences Project
> School of Human Evolution and Social Change, ASU
> Tempe, AZ 85287-2402
------ End of Forwarded Message
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20071126/78c56bab/attachment.html
