[GRASS-dev] Re: WinGrass testing results 6.3.0rc2
Moritz Lennert mlennert at club.worldonline.be
Tue Nov 27 04:08:42 EST 2007
On 26/11/07 21:17, Michael Barton wrote:
> Moritz and Benjamin,
> I’ve had a couple of students install the new winGRASS 6.3.0RC2 binary
> and test it. The main remaining problems are (hopefully) easy to fix.
> See below.
> The PROJ_SHARE variable is not set correctly
Yes, sorry, my fault. I forgot that this is not solved in the code yet,
so still needed to correct this manually.
(see thread
> NVIZ won’t launch (but did in a recent binary)
It works fine for me. Could you be a bit more specific (how do you
launch it ? What is the error message ?) ?
> Benjamin, any hope for the all-in-one *.exe package soon?
Are you speaking of an installer or of a self-extracting zip ?
