[GRASS-dev] More xtnmenu stuff
William Kyngesburye woklist at kyngchaos.com
Sun Sep 23 16:25:41 EDT 2007
Another problem (in addition to what Moritz found) - it's currently
GRASS_ADDON_ETC, not GRASS_ETC_PATH.  (and could change if we decide
on a GRASS_XTN_PATH base path instead of multiple GRASS_ADDON_* vars)
And, for the cases where people do install addons in the GRASS
installation, you might want to check for xtnmenu.dat in GISBASE.
Lastly, how about inserting a separator between xtnmenu.dat's, when
there are multiple ones found?  Sortof a visual cue that they are
from different places.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an
illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
