[GRASS-dev] Re: More xtnmenu stuff
Michael Barton michael.barton at asu.edu
Sun Sep 23 20:40:49 EDT 2007
William and Moritz
On 9/23/07 1:25 PM, "William Kyngesburye" <woklist at kyngchaos.com> wrote:
> Another problem (in addition to what Moritz found) - it's currently
> GRASS_ADDON_ETC, not GRASS_ETC_PATH.
I fixed both of these issues. Thanks for setting me straight.
> (and could change if we decide
> on a GRASS_XTN_PATH base path instead of multiple GRASS_ADDON_* vars)
I'd recommend keeping the xtnmenu.dat file in GRASS_ADDON_ETC because that
is already an existing GRASS environmental variable.
I'd also recommend using GRASS_ADDON_PATH for the same reason. Anything
listed in GRASS_ADDON_PATH will automatically run from the command line and
from in scripts (like the GUI) without an explicit path specification.
> And, for the cases where people do install addons in the GRASS
> installation, you might want to check for xtnmenu.dat in GISBASE.
No. This is the idea of a standard--so we don't have to check all the places
that people *might* try to put a menu file. If it is not in the standard
local (which is anywhere, but must be a place specified in GRASS_ADDON_ETC),
then it won't show up in the GUI.
> Lastly, how about inserting a separator between xtnmenu.dat's, when
> there are multiple ones found?  Sortof a visual cue that they are
> from different places.
Good idea. Done.
Michael
Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
