[GRASS-dev] Re: [GRASS-SVN] r32550 - grass/trunk/raster/r.colors
Wed Aug 6 11:47:24 EDT 2008
Markus Neteler wrote:
> > Modified:
> >   grass/trunk/raster/r.colors/main.c
> > Log:
> > Remove color=rules (redundant; use -i instead)
> I have updated the description.html accordingly.
> But:
> -i Enter rules interactively
> I find this description somewhat misleading for the example in
> description.html (think newcomer here):
> "The color table can then by assigned to map 'threecats' by the following
> GRASS command:
> cat rules.file | r.colors -i map=threecats
> Suggestions for better wording in the flag description (main.c)?
	"Read rules from standard input (stdin)"
