[GRASS-dev] r.out.gdal, again
Markus Metz markus_metz at gmx.de
Wed Aug 20 07:06:40 EDT 2008
Maciej Sieczka wrote:
> Markus Metz pisze:
>> Nodata value handling
>> If a nodata value was supplied, this value is tested whether it is
>> within the range of the selected data type and adjusted if necessary.
>> Specifying e.g. a nodata value of -9999 and using Byte as data type
>> (range 0 - 255) is no longer accepted, it will be adjusted to 0.
>> Similarly, a nodata value of 9999 would be adjusted to 255 for Byte
>> type.
> IMHO r.out.gdal should abort with an error rather than silently adjust
> user-specified values.
Aborting with an error is definitively an option, but then the original
behaviour of r.out.gdal should be changed too. The original r.out.gdal
chooses a nodata value according to the selected output data type if
none was specified, without message or warning. Later on (original
nodata value handling), a warning message is issued if there are NULLs
in the raster to be exported, irrespective of whether a nodata value was
specified by the user or not.
With my version, the nodata value is not silently adjusted, a warning
message is issued. I wanted to keep the behaviour similar to the
original version, and if everything is all right, there is no difference
apart from the additional -c flag and a warning if colortable export
takes place.
r.out.gdal nodata handling could be changed so that the user has to
provide a nodata value if there are NULLs in the raster, otherwise
r.out.gdal aborts with an error. Further on, r.out.gdal can also abort
with an error if the specified nodata value is not covered by the range
of the selected data type, instead of adjusting the nodata value and
issuing a warning message.
IMHO, either a warning or an error message should be issued and the type
of message - warning or error - should be consistent for nodata handling
in the whole module. If the general policy is not to adjust
user-specified values, even with a warning message, but to abort with an
error and provide information on what's wrong and how to fix it, then it
should be changed to aborting with an error. In any case, this is easy
to change.
Markus
