[GRASS-dev] r.out.gdal, again
Wed Aug 20 09:39:20 EDT 2008
Markus Metz wrote:
> r.out.gdal nodata handling could be changed so that the user has to
> provide a nodata value if there are NULLs in the raster, otherwise
> r.out.gdal aborts with an error.
That's reasonable for integer maps, but for FP maps it makes more
sense to simply default to NaN as the no-data value (the two are
essentially the same concept, so there is no information loss in using
NaN).
