[GRASS-dev] module ->label versus ->description
Martin Landa landa.martin at gmail.com
Mon Feb 4 05:48:41 EST 2008
2008/2/4, Hamish <hamish_b at yahoo.com>:
> > Hamish wrote:
> > > I notice these two changes:  (are there more?)
> > >   http://trac.osgeo.org/grass/changeset/25463
> > >   http://trac.osgeo.org/grass/changeset/29533
> > > They are good candidates to use both module->label and
> > > module->description. Using both of those is not an error. If the
> > > GUI or lib/parser.c fails to deal with that, the bug is not in the
> > > module.
> Martin:
> > I am not sure about using tooltips for module description (i.e.
> > label/description). The tooltip can be moved to the manual page
> > ('description' section). See [1].
> > [1]
> > http://www.nabble.com/Re%3A-new-std-options-for-files-p12554008.html
> ok, if you follow the thread view from that post you can see Glynn's
> replies of Sep 8, 2007 and Mar 23, 2007 which should help explain it.
> The dual role of ->description is a bit confusing at first but makes
> some sense once it is explained.
> A module's (or option's) sub-title need not be shown or thought of as a
> tooltip. e.g. --help, --html-description, the TclTk GUI and
> tools/module_synopsis.sh all handle it well. For module options, making
> it into a tooltip is just a handy thing to do with it. I would hope
> wxGUI would handle module->label in a similar way to the TclTk GUI
> (unfortunately I still wait for Debian+wx2.8 issues to be resolved
> before I can help).
> If the information is important enough to be used as a subtitle, by all
> means it should be mentioned in the help page as well.
The wxGUI would handle module->label as well, it is trivial issue. I
am not sure, should I revert these two changes (to add module->label)?
Regards, Martin
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
