[GRASS-dev] Re: [GRASS GIS] #36: v.generalize Assertion failed.
Daniel Bundala bundala at gmail.com
Sun Feb 10 03:37:18 EST 2008
Hello,
Finally, I had some time to look at it carefully. It seems to me that
the problem is the same as the one I mentioned earlier. I made a patch
some time ago, but for some obscure reasons, it did not propagate to
the SVN. I think that the patch should fix it as it is the only
difference between the version in SVN and on my computer.
Daniel
PS: I am not a big expert on CVS/SVN so the patch may be little out of date.....
Index: smoothing.c
RCS file: /home/grass/grassrepository/grass6/vector/v.generalize/smoothing.c,v
retrieving revision 1.2
diff -u -r1.2 smoothing.c
--- smoothing.c	3 Nov 2007 13:10:57 -0000	1.2
+++ smoothing.c	16 Dec 2007 18:35:00 -0000
@@ -258,7 +258,12 @@
 void refine_tangent(POINT * p)
     double l = point_dist2(*p);
-    point_scalar(*p, (double)1.0 / sqrt(sqrt(sqrt(l))), p);
+    if (l < 1e-12) {
+	point_scalar(*p, 0.0, p);
+    else {
+	point_scalar(*p, (double)1.0 / sqrt(sqrt(sqrt(l))), p);
     return;
@@ -281,7 +286,7 @@
     /* line is too short */
     if (n <= 2) {
-	return 1;
+	return n;
     /* convert degrees=>radians */
>   Reporter:  marisn   |       Owner:  grass-dev at lists.osgeo.org
>       Type:  defect   |      Status:  new
>   Priority:  major    |   Milestone:  6.4.0
>  Component:  default  |     Version:  svn-trunk
> Resolution:           |    Keywords:
> Comment (by martinl):
>  > On my machine (Debian GNU/Linux, 32bit, grass-svn) I get the same error
>  > Registering lines: v.generalize: index.c:157: RTreeInsertRect: Assertion
>  `r->boundary[i] <= r->boundary[3+i]' failed.
>  sorry, I forgot to add debug output
>  D3/5: Register node 391690.000000,392030.000000
>  D3/5: dig_find_node()
>  D3/5: node = 0
>  D3/5: dig_add_node(): n_nodes = 11, alloc_nodes = 1000
>  D3/5: dig_spidx_add_node(): node = 12, x,y,z = 391690.000000,
>  392030.000000, 0.000000
>  D3/5: new node = 12, n_nodes = 12, alloc_nodes = 1000
>  D3/5: Add new node: 12
>  D3/5: dig_node_add_line(): node = 12 line = -12
>  D3/5: dig_node_alloc_line(): add = 1
>  D5/5: dig_line_degenerate()
>  D3/5:     angle = nan
>  D3/5: dig_node_add_line(): line -12 added position 1 n_lines: 1 angle nan
>  D3/5: dig_spidx_add_line(): line = 12
>  v.generalize: index.c:157: RTreeInsertRect: Assertion `r->boundary[i] <=
>  Aborted
> Ticket URL: <http://trac.osgeo.org/grass/ticket/36#comment:4>
> GRASS GIS <http://grass.osgeo.org>
> GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
> grass-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-dev
