[GRASS-dev] [GRASS GIS] #54: g.remove mixes raster and vector maps: "Remove reclassed map first"
GRASS GIS trac at osgeo.org
Tue Feb 19 00:45:11 EST 2008
 Reporter:  neteler  |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect   |      Status:  new
 Priority:  major    |   Milestone:  6.4.0
Component:  default  |     Version:  unspecified
 Keywords:           |
 A strange bug appeared: Trying to remove a vector map, g.remove gets
 confused with a non-exiting reclass map
 GRASS 6.3.svn (pat):~ > g.remove
 vect=lst_20050101_avg,lst_20050101_avg2,lst_200501_avg_filt
 WARNING: [lst_20050101_avg at modisLSTzanzara] is a base map. Remove
 reclassed
          map first: MASK at modisLSTzanzara
 Removing vector <lst_20050101_avg2>
 WARNING: [lst_200501_avg_filt at modisLSTzanzara] is a base map. Remove
          reclassed map first: MASK at modisLSTzanzara
 GRASS 6.3.svn (pat):~ > g.remove vect=lst_20050101_avg
 reclassed
 GRASS 6.3.svn (pat):~ > g.list rast | grep lst_20050101_avg
 lst_20030114_avg                        lst_20050101_avg
 lst_20030115_avg                        lst_20050101_avg_lstmodel
 GRASS 6.3.svn (pat):~ > g.list vect | grep lst_
 lst_20050101_avg    lst_200501_avg_filt
 GRASS 6.3.svn (pat):~ > r.info lst_20050101_avg | grep generated
  |    generated by r.series
 GRASS 6.3.svn (pat):~ > g.gisenv
 GISDBASE=/home/neteler/grassdata
 LOCATION_NAME=pat
 MAPSET=modisLSTzanzara
 DEBUG=0
 GRASS_GUI=text
 MONITOR=x0
 The problem seems to be in source:grass/trunk/general/manage/cmd/remove.c
 (line 83) where it should not enter. Fix appreciated..
 Markus
Ticket URL: <http://trac.osgeo.org/grass/ticket/54>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
