[GRASS-dev] [GRASS GIS] #54: g.remove mixes raster and vector maps: "Remove reclassed map first"
Tue Feb 19 22:48:30 EST 2008
>  Reporter:  neteler  |       Owner:  grass-dev at lists.osgeo.org
>      Type:  defect   |      Status:  new
>  Priority:  major    |   Milestone:  6.4.0
> Component:  default  |     Version:  unspecified
>  Keywords:           |
>  A strange bug appeared: Trying to remove a vector map, g.remove gets
>  confused with a non-exiting reclass map
>  GRASS 6.3.svn (pat):~ > g.remove
>  vect=lst_20050101_avg,lst_20050101_avg2,lst_200501_avg_filt
>  WARNING: [lst_20050101_avg at modisLSTzanzara] is a base map. Remove
>  reclassed
>           map first: MASK at modisLSTzanzara
>  Removing vector <lst_20050101_avg2>
>  WARNING: [lst_200501_avg_filt at modisLSTzanzara] is a base map. Remove
>           reclassed map first: MASK at modisLSTzanzara
>  GRASS 6.3.svn (pat):~ > g.remove vect=lst_20050101_avg
>  reclassed
>  GRASS 6.3.svn (pat):~ > g.list rast | grep lst_20050101_avg
>  lst_20030114_avg                        lst_20050101_avg
>  lst_20030115_avg                        lst_20050101_avg_lstmodel
>  GRASS 6.3.svn (pat):~ > g.list vect | grep lst_
>  lst_20050101_avg    lst_200501_avg_filt
>  GRASS 6.3.svn (pat):~ > r.info lst_20050101_avg | grep generated
>   |    generated by r.series
>  GRASS 6.3.svn (pat):~ > g.gisenv
>  GISDBASE=/home/neteler/grassdata
>  LOCATION_NAME=pat
>  MAPSET=modisLSTzanzara
>  DEBUG=0
>  GRASS_GUI=text
>  MONITOR=x0
>  The problem seems to be in source:grass/trunk/general/manage/cmd/remove.c
>  (line 83) where it should not enter. Fix appreciated..
Can you test the attached patch?
Index: general/manage/cmd/remove.c
--- general/manage/cmd/remove.c	(revision 30265)
+++ general/manage/cmd/remove.c	(working copy)
@@ -24,6 +24,74 @@
 #include "list.h"
 #include "local_proto.h"
+static int
+check_reclass(const char *name, const char *mapset, int force)
+    char rname[GNAME_MAX], rmapset[GMAPSET_MAX];
+    char **rmaps;
+    int nrmaps;
+    if (G_is_reclassed_to(name, mapset, &nrmaps, &rmaps) > 0)
+	for ( ; *rmaps; rmaps++)
+	    /* force remove */
+	    if (force)
+		G_warning(
+		    _("[%s@%s] is a base map for [%s]. Remove forced."),
+		    name, mapset,  *rmaps);
+	    else
+		G_warning(
+		    _("[%s@%s] is a base map. Remove reclassed map first: %s"),
+	if (!force)
+	    return 1;
+    if (G_is_reclass(name, mapset, rname, rmapset) > 0 &&
+	G_is_reclassed_to(rname, rmapset, &nrmaps, &rmaps) > 0)
+	char path[GPATH_MAX];
+	char *p = strchr(rname, '@');
+	char *qname = G_fully_qualified_name(name, mapset);
+	if (p)
+	    *p = '\0';
+	G__file_name_misc(path, "cell_misc", "reclassed_to", rname, rmapset);
+	if(nrmaps == 1 && !G_strcasecmp(rmaps[0], qname))
+	    if (remove(path) < 0)
+		G_warning(
+		    _("Removing information about reclassed map from [%s@%s] failed"),
+		    rname, rmapset);
+	else
+	    FILE *fp = fopen(path, "w");
+	    if (fp)
+		    if (G_strcasecmp(*rmaps, qname))
+			fprintf(fp, "%s\n", *rmaps);
+		fclose(fp);
+	    else
+		G_warning(
+		    rname, rmapset);
+    return 0;
 int
 main (int argc, char *argv[])
@@ -32,10 +100,7 @@
     struct Option **parm, *p;
     struct Flag *force_flag;
     char *name, *mapset;
-    char rname[256], rmapset[256];
-    int nrmaps;
-    char **rmaps, *location_path;
-    FILE *fp;
+    char *location_path;
     int result = EXIT_SUCCESS;
     int force = 0;
@@ -80,62 +145,10 @@
 	if (parm[n]->answers)
 	    for (i = 0; (name = parm[n]->answers[i]); i++)
-		if(G_is_reclassed_to(name, mapset, &nrmaps, &rmaps) > 0)
-		    for(; *rmaps; rmaps++) {
-                        /* force remove */
-                        if ( force ) {
-                            G_warning(
-                            _("[%s@%s] is a base map for [%s]. Remove forced."),
-                                                name, mapset,  *rmaps);
-                        else {
-                            G_warning(
-                            _("[%s@%s] is a base map. Remove reclassed map first: %s"),
-                    if ( !force )
-                        continue;
-		if(G_is_reclass(name, mapset, rname, rmapset) > 0 &&
-		   G_is_reclassed_to(rname, rmapset, &nrmaps, &rmaps) > 0)
-		    char path[GPATH_MAX];
-		    char *p = strchr(rname, '@');
-		    char *qname = G_fully_qualified_name(name, mapset);
-		    if (p)
-			*p = '\0';
-		    G__file_name_misc(path, "cell_misc", "reclassed_to", rname, rmapset);
+		if (G_strcasecmp(list[n].alias, "rast") == 0 &&
+		    check_reclass(name, mapset, force))
+		    continue;
-		    if(nrmaps == 1 && !G_strcasecmp(rmaps[0], qname))
-		        if (  remove(path) < 0 ) {
-                            G_warning(
-                            _("Removing information about reclassed map from [%s@%s] failed"),
-                                                rname, rmapset);
-		    else
-		        if ( (fp = fopen(path, "w")) ) {
-                                if(G_strcasecmp(*rmaps, qname))
-                                    fprintf(fp, "%s\n", *rmaps);
-                            fclose(fp);
-                        else {
-                            G_warning(
-                                                rname, rmapset);
 		if ( do_remove (n, name) == 1 )
 		    result = EXIT_FAILURE;
