[GRASS-dev] missing help for r.cats
    Glynn Clements
    glynn at gclements.plus.com
    Wed Feb 20 08:46:42 EST 2008
Hamish wrote:
> > 	The proper command to search for the latter (assuming POSIX
> > 	`grep' [1]) is:
> > $ grep -F r.cats *
> Right. FWIW my method was 'grep -rI r\.cats *'
If you're doing that from the shell, it needs two backslashes:
	grep -rI r\\.cats *
or quotes:
	grep -rI 'r\.cats' *
so that grep actually "sees" a backslash.
Or just use "grep -F" or "fgrep" for searching for fixed strings.
