[GRASS-dev] Re: [R-sig-Geo] Plan to build Package to use GRASS from R
Roger Bivand Roger.Bivand at nhh.no
Thu Feb 28 02:29:08 EST 2008
On Wed, 27 Feb 2008, Rainer M Krug wrote:
> Hi
> Sorry for crossposting, but I think this can be of interest for GRASS and R
> users.
Yes, please avoid cross-posting - the discussion ends up on many different
lists and threading can break down if the threading implementation in mail
clients and archives doesn't like cross-posting.
The only complete thread I have found is on Nabble at:
http://www.nabble.com/Plan-to-build-Package-to-use-GRASS-from-R-tt15712877.html#a15712877
for the grass-dev list.
In summary, the problems are mostly those of appropriately quoting shell
commands through system() across platforms. Those interested should follow
the discussion on grass-dev.
The correct lists could be either here, or the grass-stats list; could
Rainer post a summary to both (hopefully in-thread) on conclusion?
Roger
> I am planning to write a package to make the use of GRASS from R easier. The
> idea is to wrap the system call to execute the GRASS command into an R
> command of the same name.
> e.g:
> r.to.vect <- function(..., intern=TRUE, ignore.stderr=FALSE)
>    comm <- paste( "r.to.vect ", ..., sep="" )
>    print(comm)
>    system( comm, intern=intern, ignore.stderr=ignore.stderr )
> My questions are:
> 1) Is this a good way of doing it, or is giving a named list to the function
> more usefull?
> 2) Is there a way to obtain easily all commands from GRASS and the
> parameters possible and required?
> Any ideas and comments welcome,
> Rainer
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Helleveien 30, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
