[GRASS-dev] G_message () family of functions
    Glynn Clements
    glynn at gclements.plus.com
    Sun Jan 13 19:06:57 EST 2008
Ivan Shmakov wrote:
>  > BTW, the correct pattern for issuing a string message is:
>  > G_message ("%s", string);
>  > not:
>  > G_message (string);
> 	May I suggest the following patch?
Seems reasonable enough.
> --- lib/gis/error.c	2008-01-03 14:15:58.000000000 +0600
> +++ lib/gis/error.c	2008-01-12 23:14:50.000000000 +0600
> @@ -93,6 +93,16 @@
>                          time_t, const char *);
>  static int log_error (const char *, int);
> +static int
> +vfprint_error (int type, const char *template, va_list ap)
> +    char buffer[2000];  /* G_asprintf does not work */
> +    vsprintf (buffer, template, ap);
It would be nice to use vsnprintf(), but we would need to check that
it's available (it's not in C89).
