[GRASS-dev] rsdriver and rsdatabase options for v.lrs.where?
William A. Perkins
william.perkins at pnl.gov
Thu Jan 17 13:59:10 EST 2008
Hello,
Perhaps I'm being naive, but I don't understand why v.lrs.segment has
the rstable and rsdriver options but the other v.lrs.* commands don't.
I've attached a patch (against today's CVS) for v.lrs.where, that's
just a copy and paste from v.lrs.segment. It seems to work for me,
i.e., I can run v.lrs.where in a mapset (and db) other than the one
where the LRS was created.
Please tell me why this is bad.
Thanks.
Bill
Bill Perkins
Pacific Northwest National Laboratory
Hydrology Group
P.O. Box 999 MSIN K9-36
Richland, Washington, USA 99352
voice: (509) 372-6131 fax: (509) 372-6089 email: william.perkins at pnl.gov
Index: vector/v.lrs/v.lrs.where/main.c
RCS file: /home/grass/grassrepository/grass6/vector/v.lrs/v.lrs.where/main.c,v
retrieving revision 1.7
diff -u -r1.7 main.c
--- vector/v.lrs/v.lrs.where/main.c 10 Aug 2007 14:49:54 -0000 1.7
+++ vector/v.lrs/v.lrs.where/main.c 17 Jan 2008 18:55:00 -0000
@@ -39,9 +39,10 @@
double thresh, multip;
struct Option *lines_opt, *points_opt;
struct Option *lfield_opt, *pfield_opt;
- struct Option *table_opt, *thresh_opt;
+ struct Option *driver_opt, *database_opt, *table_opt, *thresh_opt;
struct GModule *module;
char *mapset;
+ char *drv, *db;
struct Map_info LMap, PMap;
struct line_cats *LCats, *PCats;
struct line_pnts *LPoints, *PPoints;
@@ -74,6 +75,22 @@
pfield_opt->answer = "1";
pfield_opt->description = _("Point layer");
+ driver_opt = G_define_option() ;
+ driver_opt->key = "rsdriver" ;
+ driver_opt->type = TYPE_STRING ;
+ driver_opt->required = NO;
+ driver_opt->description = _("Driver name for reference system table");
+ if ( (drv=db_get_default_driver_name()) )
+ driver_opt->answer = drv;
+ database_opt = G_define_option() ;
+ database_opt->key = "rsdatabase" ;
+ database_opt->type = TYPE_STRING ;
+ database_opt->required = NO;
+ database_opt->description = _("Database name for reference system table");
+ if ( (db=db_get_default_database_name()) )
+ database_opt->answer = db;
table_opt = G_define_option() ;
table_opt->key = "rstable" ;
table_opt->type = TYPE_STRING ;
@@ -118,8 +135,8 @@
db_init_handle (&rshandle);
db_init_string (&rsstmt);
- rsdriver = db_start_driver(NULL);
- db_set_handle (&rshandle, NULL, NULL);
+ rsdriver = db_start_driver(driver_opt->answer);
+ db_set_handle (&rshandle, database_opt->answer, NULL);
if (db_open_database(rsdriver, &rshandle) != DB_OK)
G_fatal_error(_("Unable to open database for reference table"));
