[GRASS-dev] svn seems to complete commit to repository, but hang locally
Michael Barton michael.barton at asu.edu
Fri Jan 25 18:59:00 EST 2008
I've never had the SVN hang for me while doing a commit, checkout, or
update on my Mac in the short time it has been up.
However, it recently took all day to do an SVN checkout from our lab
FC6 box. We tried it several times and finally just went off and left
it.
Michael
______________________________
Michael Barton, Professor
Professor of Anthropology
Director of Graduate Studies
School of Human Diversity & Social Change
Center for Social Dynamics & Complexity
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
On Jan 25, 2008, at 3:52 PM, grass-dev-request at lists.osgeo.org wrote:
> Message: 5
> Date: Fri, 25 Jan 2008 15:23:12 -0500
> From: Frank Warmerdam <warmerdam at pobox.com>
> Subject: Re: [GRASS-dev] svn seems to complete commit to repository,
> 	but hang	locally
> To: "Patton, Eric" <epatton at nrcan.gc.ca>
> Cc: grass-dev at lists.osgeo.org
> Message-ID: <479A4530.1020006 at pobox.com>
> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> Patton, Eric wrote:
>> On Jan 25, 2008 6:35 PM, Patton, Eric <epatton at nrcan.gc.ca> wrote:
>>>> I'm having trouble with svn today...for some reason, the svn
>>>> commit hangs at "Transmitting file data ." even though the commit
>>>> seems to have been completed and is browse-able on the
>>>> repository. >>Has anyone had trouble uploading commits? Server
>>>> problem, maybe?
>>> Eric,
>>> I was told that this happens when the CIA IRC bot hangs
>>> (http://cia.vc/stats/project/GRASS).
>>> The SVN server should be ok. If you can access IRC, you could in
>>> those moments
>>> irc://irc.freenode.net/osgeo
>>> or
>>> irc://irc.freenode.net/telascience (preferred). Then the OSGeo
>>> sysadmins could check.
>>> Markus
>> Thanks for the hints; I'll give it a try next time.
> Eric / Markus,
> I've heard this claim about the CIA IRC stuff too but I'm not at all
> convinced it is true.  The CIA aspect is initiated by an email from
> the svn commit hook script and the sending of that email is done by
> running a command in the background.  I don't see how this could hold
> up the overall svn transaction.
> I personally have a very high latency satellite connection and https
> transactions (as I hope you are using for svn) is very slow over this
> link.  I also have problems with svn actions appearing to hang even
> though
> from other signs I can see that all the server side action went fine.
> I generally end up having to control-c the commit after a couple
> minutes of
> no action and then do an "svn cleanup ; svn update" to fix up my local
> repository.
> It is possible these issues are somehow related to a problem on the
> svn.osgeo.org server, but I haven't been able to isolate anything in
> the
> past.  If you are seeing persistent problems, dropping into #osgeo and
> letting us know so we can check the server side is a good idea.
> But I don't *think* it is really CIA related.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGeo, http://osgeo.org
