[GRASS-dev] Re: [GRASS GIS] #175: v.to.rast labelcol= SegFault
GRASS GIS trac at osgeo.org
Wed Jun 18 09:03:58 EDT 2008
  Reporter:  hamish   |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  major    |   Milestone:  6.4.0
 Component:  default  |     Version:  unspecified
Resolution:           |    Keywords:  v.to.rast
Comment (by hamish):
 perhaps a red herring:
 in gdb frame # 2 the raster cat source string is:
   s=0x808c450 "\"NO DATA\""
 note this is raster category 0. The vector map version of "fields" has a
 cat 0, so maybe that's legal, albeit uncommon, vector cat value.
 but more to the point, this is where/why it SegFaults:
 lib/db/dbmi_client/select.c
   if ( count == 0 ) db_copy_value ( val, value );
   // ie copy(destination, source)
 the destination memory address (val->s->string) is out of bounds. nalloc
 is 48, which seems ok.
 that variable is created in v.to.rast/support.c line 296 with:
   dbValue value;
 and then passed to db_select_value().
 dbValue is defined in include/dbmi.h:
  typedef struct _db_value {
     char       isNull;
     int        i;
     double     d;
     dbString   s;
     dbDateTime t;
  } dbValue;
  typedef struct _db_string {
     char *string;
     int nalloc;
  } dbString;
 so that dbString is being used as a target without having been malloc'd
 first? I am not sure where s->nalloc=48 gets set, that's a bit of a
 mystery to me.
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/175#comment:3>
