[GRASS-dev] GDAL 1.5.0 Build Error With GRASS Support
Marco Pasetti marco.pasetti at alice.it
Tue Mar 4 16:51:03 EST 2008
Hi Markus,
I already checked it out... but it seems that there's still not a
grass-plugin for latest gdal release (1.5.0); the last I found is for gdal
1.4.3
Marco
-----Messaggio originale-----
Da: neteler.osgeo at gmail.com [mailto:neteler.osgeo at gmail.com] Per conto di
Markus Neteler
Inviato: martedì 4 marzo 2008 22.41
A: Marco Pasetti
Cc: grass-dev at lists.osgeo.org
Oggetto: Re: [GRASS-dev] GDAL 1.5.0 Build Error With GRASS Support
Hi Marco,
please don't build GDAL with direct GRASS support but use the plugin instead
(way easier...). See
http://grass.gdf-hannover.de/wiki/Compile_and_install_GRASS_and_QGIS_with_GD
AL/OGR_Plugin
cheers
Markus
On Tue, Mar 4, 2008 at 9:24 PM, Marco Pasetti <marco.pasetti at alice.it>
wrote:
> Problem fixed
> needed only to add --with-local=/usr/local in configure
> Marco
>  ________________________________
>  Da: grass-dev-bounces at lists.osgeo.org
> [mailto:grass-dev-bounces at lists.osgeo.org] Per conto di
> Inviato: martedì 4 marzo 2008 18.03
> A: grass-dev at lists.osgeo.org
> Oggetto: [GRASS-dev] GDAL 1.5.0 Build Error With GRASS Support
> Hi,
> I'm building GDAL 1.5.0 with GRASS support; it gives the following
> error:
> In file included from grass57dataset.cpp:45:
> C:/MSYS/local/grass-6.3.0RC5/include/grass/gprojects.h:23:22:
> proj_api.h: No such file or directory In file included from
> C:/MSYS/local/grass-6.3.0RC5/include/grass/gprojects.h:36: error: ISO
> C++ forbids declaration of `projPJ' with no type
> expected `;' before '*' token
> make[2]: *** [../o/grass57dataset.o] Error 1
> make[2]: Leaving directory `/usr/local/src/gdal-1.5.0/frmts/grass'
> make[1]: *** [grass-install-obj] Error 2
> make[1]: Leaving directory `/usr/local/src/gdal-1.5.0/frmts'
> make: *** [frmts-target] Error 2
> proj_api.h is present in /usr/local/include, while
> /usr/local/grass-6.3.0RC5/include/grass has gproj_api.h should I force
> GRASS code to include gproj_api.h instead of proj_api.h or walk around
> the problem adding /usr/local/include to PATH before launch make
> command?
> Thanks
> Marco
>  grass-dev mailing list
>  http://lists.osgeo.org/mailman/listinfo/grass-dev
Open Source Geospatial Foundation
http://www.osgeo.org/
http://www.grassbook.org/
