[GRASS-dev] Re: GDAL 1.5.0 Build Error With GRASS Support
Markus Neteler neteler at osgeo.org
Tue Mar 4 17:07:30 EST 2008
Hi Marco,
(cc Frank)
I assume that the plugin for gdal 1.4.3 also works for gdal 1.5.0.
Markus
On Tue, Mar 4, 2008 at 10:51 PM, Marco Pasetti <marco.pasetti at alice.it> wrote:
> Hi Markus,
>  I already checked it out... but it seems that there's still not a
>  grass-plugin for latest gdal release (1.5.0); the last I found is for gdal
>  1.4.3
>  Marco
>  -----Messaggio originale-----
>  Da: neteler.osgeo at gmail.com [mailto:neteler.osgeo at gmail.com] Per conto di
>  Markus Neteler
>  Inviato: martedì 4 marzo 2008 22.41
>  A: Marco Pasetti
>  Cc: grass-dev at lists.osgeo.org
>  Oggetto: Re: [GRASS-dev] GDAL 1.5.0 Build Error With GRASS Support
>  Hi Marco,
>  please don't build GDAL with direct GRASS support but use the plugin instead
>  (way easier...). See
>  http://grass.gdf-hannover.de/wiki/Compile_and_install_GRASS_and_QGIS_with_GD
>  AL/OGR_Plugin
>  cheers
>  Markus
>  On Tue, Mar 4, 2008 at 9:24 PM, Marco Pasetti <marco.pasetti at alice.it>
>  wrote:
>  > Problem fixed
>  > needed only to add --with-local=/usr/local in configure
>  > Marco
>  >  ________________________________
>  >  Da: grass-dev-bounces at lists.osgeo.org
>  > [mailto:grass-dev-bounces at lists.osgeo.org] Per conto di
>  > Inviato: martedì 4 marzo 2008 18.03
>  > A: grass-dev at lists.osgeo.org
>  > Oggetto: [GRASS-dev] GDAL 1.5.0 Build Error With GRASS Support
>  > Hi,
>  > I'm building GDAL 1.5.0 with GRASS support; it gives the following
>  > error:
>  > In file included from grass57dataset.cpp:45:
>  > C:/MSYS/local/grass-6.3.0RC5/include/grass/gprojects.h:23:22:
>  > proj_api.h: No such file or directory In file included from
>  > C:/MSYS/local/grass-6.3.0RC5/include/grass/gprojects.h:36: error: ISO
>  > C++ forbids declaration of `projPJ' with no type
>  > expected `;' before '*' token
>  > make[2]: *** [../o/grass57dataset.o] Error 1
>  > make[2]: Leaving directory `/usr/local/src/gdal-1.5.0/frmts/grass'
>  > make[1]: *** [grass-install-obj] Error 2
>  > make[1]: Leaving directory `/usr/local/src/gdal-1.5.0/frmts'
>  > make: *** [frmts-target] Error 2
>  > proj_api.h is present in /usr/local/include, while
>  > /usr/local/grass-6.3.0RC5/include/grass has gproj_api.h should I force
>  > GRASS code to include gproj_api.h instead of proj_api.h or walk around
>  > the problem adding /usr/local/include to PATH before launch make
>  > command?
>  > Thanks
>  > Marco
>  > _______________________________________________
>  >  grass-dev mailing list
>  >  http://lists.osgeo.org/mailman/listinfo/grass-dev
>  Open Source Geospatial Foundation
>  http://www.osgeo.org/
>  http://www.grassbook.org/
