[GRASS-dev] build problems on Mac OS X 10.5.2.
John Kern kernj at kernj.cnc.net
Thu May 8 22:26:32 EDT 2008
I am trying to build Grass from source on Leopard(Mac OS X 10.5.2 with
gcc 4.0.1).
While PROJ.4 built and installed without problem,  configure failed
for GRASS proper. The resulting error is ...
"checking External PROJ.4 version... configure: error: *** Could not
determine External PROJ.4 version."
Consider this line from the trace output of the configure script.
+ eval echo configure:6910: '"${CC-cc}' -o conftest '$CFLAGS'
'$CPPFLAGS' '$LDFLAGS' 'conftest.$ac_ext' '$LIBS' '1>&5"'
++ echo configure:6910: 'gcc -o conftest.dSYM -g -O2      conftest.c
The dSYM file extension on the output file is the critical bit. If the
output file ends with a dSYM file extension, only supporting data is
generated. No executable. (see example below). I worked around the
problem by deleting references to ${ac_exeext}.  What's the right fix
for the configure script? Apparently there is a supporting script to
autoconf which needs to be updated, right?
%%% with file extension - no executable
[Macintosh:grass/grass63_release/try] jkern% gcc -o try.dSYM -g -O2
[Macintosh:grass/grass63_release/try] jkern% ls -l
total 8
-rw-r--r--  1 jkern  staff  171 May  2 16:04 try.c
drwxr-xr-x  3 jkern  staff  102 May  8 18:02 try.dSYM
[Macintosh:grass/grass63_release/try] jkern% ls -R
try.c           try.dSYM
Info.plist      Resources
%%%% without the extension - all is well.
[Macintosh:grass/grass63_release/try] jkern% gcc -o try -g -02 try.c
total 40
-rwxr-xr-x  1 jkern  staff  12832 May  8 19:24 try
drwxr-xr-x  3 jkern  staff    102 May  8 19:24 try.dSYM
