[GRASS-dev] GRASS 7 development started
Martin Landa landa.martin at gmail.com
Wed May 28 16:33:58 EDT 2008
2008/5/28 Markus Neteler <neteler at osgeo.org>:
> On Wed, May 28, 2008 at 5:55 PM, Glynn Clements
> <glynn at gclements.plus.com> wrote:
>> Two people (myself, Paul) supported -bl (opening brace on line after
>> if/for/while), while two (Hamish, Ivan) favoured -br (opening brace on
>> same line). Does anyone want to cast the deciding vote here?
> Note sure if mine should be the deciding vote here 8others, please!).
> I find the opening brace on same line better as files are getting shorter
> and since most editors jump to the other brace for a moment to
> indicate it.
well, I hesitate to be also deciding vote here, also +1 for -br
(opening brace on same line).
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
