[GRASS-dev] GRASS 7 development started
Markus Neteler neteler at osgeo.org
Wed May 28 16:26:15 EDT 2008
On Wed, May 28, 2008 at 5:55 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Two people (myself, Paul) supported -bl (opening brace on line after
> if/for/while), while two (Hamish, Ivan) favoured -br (opening brace on
> same line). Does anyone want to cast the deciding vote here?
Note sure if mine should be the deciding vote here 8others, please!).
I find the opening brace on same line better as files are getting shorter
and since most editors jump to the other brace for a moment to
indicate it.
Markus
