[GRASS-dev] nviz compile errors on Mac OS X
Michael Barton michael.barton at asu.edu
Sat Sep 13 14:59:16 EDT 2008
Just did an update and compile of develbranch_6
../lib/nviz compiles but ../gui/wxpython/nviz does not. Here are the
errors.
cmb-MBP-2:g.mremove cmbarton$ cd /Users/cmbarton/grass_dev/grass6_src/
gui/wxpython/nviz
cmb-MBP-2:nviz cmbarton$ make
c++ -I/Users/cmbarton/grass_dev/grass6_src/dist.i386-apple-darwin9.4.0/
include  -g -O2   -fno-common -I/Library/Frameworks/GDAL.framework/
Versions/1.5/Headers -I/Library/Frameworks/Python.framework/Versions/
2.5/include/python2.5 -I/Library/Frameworks/Python.framework/Versions/
2.5/include/python2.5 -arch ppc -arch i386 -isysroot /Developer/SDKs/
MacOSX10.4u.sdk -fno-strict-aliasing -Wno-long-double -no-cpp-precomp -
mno-fused-madd -fno-common -dynamic -DNDEBUG -g -O3 -I/usr/lib/wx/
include/mac-unicode-debug-2.8 -I/usr/include/wx-2.8 -
D_FILE_OFFSET_BITS=64 -D_LARGE_FILES -D__WXDEBUG__ -D__WXMAC__  -I/usr/
X11/include    -DPACKAGE=\""grasslibs"\"  -I/Users/cmbarton/grass_dev/
grass6_src/dist.i386-apple-darwin9.4.0/include -o OBJ.i386-apple-
darwin9.4.0/grass6_wxnviz_wrap.o -c grass6_wxnviz_wrap.cpp
grass6_wxnviz_wrap.cpp:3165: error: expected unqualified-id before ‘{’
token
grass6_wxnviz_wrap.cpp:3173: error: expected unqualified-id before ‘{’
token
grass6_wxnviz_wrap.cpp:3180: error: expected unqualified-id before ‘{’
token
grass6_wxnviz_wrap.cpp:3241: error: expected unqualified-id before ‘{’
token
grass6_wxnviz_wrap.cpp:3781: error: expected unqualified-id before ‘{’
token
grass6_wxnviz_wrap.cpp: In static member function ‘static int
swig::traits_asptr_stdseq<Seq, T>::asptr(PyObject*, Seq**)’:
grass6_wxnviz_wrap.cpp:3889: error: expected unqualified-id before ‘?’
token
token
token
token
token
token
token
lipo: can't figure out the architecture type of: /var/folders/AK/
AKpYwDw1EoWI+fFF02nvRk+++TI/-Tmp-//ccMLYkCt.out
make: *** [OBJ.i386-apple-darwin9.4.0/grass6_wxnviz_wrap.o] Error 1
Michael
