[GRASS-dev] nviz compile errors on Mac OS X
William Kyngesburye woklist at kyngchaos.com
Mon Sep 15 09:51:16 EDT 2008
On Sep 15, 2008, at 12:12 AM, Michael Barton wrote:
> I tried poking around inside _grass6_wxvdigit.so
> I don't know if it is meaningful or not, but I found quite a few
> lines referencing things like...
> /Developer/SDKs/MacOSX10.4u.sdk/usr/include/c++/4.0.0/bits/ostream.tcc
> ...instead of the equivalent files in /Developer/SDKs/MacOSX10.5.sdk
I think that's just C++ debugging info.  No matter what you set the
isysroot (in your CXXFLAGS), if you do, the MacPython was built with
the 10.4 SDK and will use that.
Probably harmless.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"We are at war with them. Neither in hatred nor revenge and with no
particular pleasure I shall kill every ___ I can until the war is
over. That is my duty."
"Don't you even hate 'em?"
"What good would it do if I did? If all the many millions of people of
the allied nations devoted an entire year exclusively to hating the
____ it wouldn't kill one ___ nor shorten the war one day."
<Ha, ha> "And it might give 'em all stomach ulcers."
- Tarzan, on war
